0 Members and 1 Guest are viewing this topic. Read 2761 times.
Yup - because everyone has been officially 'scared' that copy protection will be implemented and if you don't have HDCP compliant HDMI, they'll either make content unavailable or down-rez'd to current DVD 480p.
Quote from: bpape on 1 Jul 2007, 06:05 pmYup - because everyone has been officially 'scared' that copy protection will be implemented and if you don't have HDCP compliant HDMI, they'll either make content unavailable or down-rez'd to current DVD 480p.I'm not sure this thread isn't playing just as fast and loose with the info as posters are claiming HDMI industry proponents are. Its not about some magic 1 cable solution (although it is VERY nice). And while I'm sure the whole copy protection is a big player in the decisions there are some things it offers that are new.Some consumers want HDMI not just because it allows HDCP, but because there are VERY FEW displays that will take 1080p over anything else. This means there is an automatic downgrade in source resolution to hookup a 1080p player with 1080p media to most 1080p displays via component. Sure it will downrez to 1080i and then the display will scale back up, but you can't tell me you aren't losing data in that process. Also keep in mind that most displays are now digital based so HDMI/DVI avoids an extra DAC/ADC step. I didn't even really mention upscaling dvd players and their reliance on HDMI/DVI (with very few exceptions), because you can argue their scaler may or may not be better than the displays itself.Now lets talk about the audio side of the fence. Digital coax/toslink will not allow newer advanced (lossless) audio formats because they don't have the bandwidth, so you have to use analog outputs. 5.1/7.1 analog inputs provide much of the same features that running HDMI uncompressed LPCM does, but keep in mind that we've now got as many as 4 sets needed then (SACD, DVD-A, HDDVD, Blu). Even if you ignore the multi-channel audio pieces you still have 2 hi rez players. That means you need 2 sets of analog 7.1 inputs. Also you are going to have the use whatever configuration options you have in that player which means less advanced bass management and no room analysis/equalization or you have to put it through an extra ADC/DAC step. Don't forget that the analog outputs on Blu/HDDVD players are going to cost much more too. The lower priced players don't have them now so you have to move up the chain. For example a PS3 will do 1080p and full 7.1 uncompressed lpcm, but it ONLY works via HDMI (for both audio and video).
If you don't have a FULLY HDCP compliant chain, you get no signal.
Yes - it down rez's because of the copy protection issue. Yes, ANY time you go through a video conversion from progressive to interlaced and back, there are artifacts.All of the information you cite about the bennies of HDMI are what has been forced on us due to copy protection issues. The uncompressed only works on HDMI because they can turn it off at any time by setting the HDCP flag. If you don't have a FULLY HDCP compliant chain, you get no signal.
You should also look at the bandwidth capabilities of the HDMI cabling itself. By the time you use the bandwidth requirements for 1080p video, I'll guarantee you there's LESS bandwidth available for audio than with an SPDIF connection.
Quote from: samplesj on 2 Jul 2007, 01:23 pmQuote from: bpape on 1 Jul 2007, 06:05 pmYup - because everyone has been officially 'scared' that copy protection will be implemented and if you don't have HDCP compliant HDMI, they'll either make content unavailable or down-rez'd to current DVD 480p.I'm not sure this thread isn't playing just as fast and loose with the info as posters are claiming HDMI industry proponents are. Its not about some magic 1 cable solution (although it is VERY nice). And while I'm sure the whole copy protection is a big player in the decisions there are some things it offers that are new.Some consumers want HDMI not just because it allows HDCP, but because there are VERY FEW displays that will take 1080p over anything else. This means there is an automatic downgrade in source resolution to hookup a 1080p player with 1080p media to most 1080p displays via component. Sure it will downrez to 1080i and then the display will scale back up, but you can't tell me you aren't losing data in that process. Also keep in mind that most displays are now digital based so HDMI/DVI avoids an extra DAC/ADC step. I didn't even really mention upscaling dvd players and their reliance on HDMI/DVI (with very few exceptions), because you can argue their scaler may or may not be better than the displays itself.Now lets talk about the audio side of the fence. Digital coax/toslink will not allow newer advanced (lossless) audio formats because they don't have the bandwidth, so you have to use analog outputs. 5.1/7.1 analog inputs provide much of the same features that running HDMI uncompressed LPCM does, but keep in mind that we've now got as many as 4 sets needed then (SACD, DVD-A, HDDVD, Blu). Even if you ignore the multi-channel audio pieces you still have 2 hi rez players. That means you need 2 sets of analog 7.1 inputs. Also you are going to have the use whatever configuration options you have in that player which means less advanced bass management and no room analysis/equalization or you have to put it through an extra ADC/DAC step. Don't forget that the analog outputs on Blu/HDDVD players are going to cost much more too. The lower priced players don't have them now so you have to move up the chain. For example a PS3 will do 1080p and full 7.1 uncompressed lpcm, but it ONLY works via HDMI (for both audio and video).Yes - it down rez's because of the copy protection issue. Yes, ANY time you go through a video conversion from progressive to interlaced and back, there are artifacts.All of the information you cite about the bennies of HDMI are what has been forced on us due to copy protection issues. The uncompressed only works on HDMI because they can turn it off at any time by setting the HDCP flag. If you don't have a FULLY HDCP compliant chain, you get no signal. You should also look at the bandwidth capabilities of the HDMI cabling itself. By the time you use the bandwidth requirements for 1080p video, I'll guarantee you there's LESS bandwidth available for audio than with an SPDIF connection.Bryan
