Can anyone recommend a good Indoor AM/FM Antenna?
0 Members and 1 Guest are viewing this topic. Read 1383 times.
puft54cs
« on: 23 May 2007, 04:16 pm »
I was wondering if anyone could recommend a good indoor AM/FM antenna? I just purchased a NAD tuner and the simple wire antenna for FM isn't doing a very good job and an outside antenna isn't feasible in my situation.  Any help would be greatly appreciated.
Nels Ferre
Re: Can anyone recommend a good Indoor AM/FM Antenna?
« Reply #1 on: 23 May 2007, 04:30 pm »
I use a Godar passive FM antenna with good results.
I have previously used a Terk amplified FM antenna, and wasn't happy with it as it amplifies not only the signal, but the noise as well.
I got mine from www.partsexpress.com.  It was less than $50 if I remember correctly.
Turnandcough
« Reply #2 on: 23 May 2007, 04:45 pm »
I use this Philips antenna. Not because it's dirt cheap but because it works better than both the standard "T" antenna that came with my Denon tuner as well as my Delhi rooftop antenna which picked up interference on some channels.
http://www.amazon.com/dp/B0001656PM/ref=nosim/?tag=yahoo-ce-20&creative=380333&creativeASIN=B0001656PM&linkCode=asn
« Last Edit: 23 May 2007, 07:02 pm by Turnandcough »
Charles Calkins
« Reply #3 on: 23 May 2007, 05:15 pm »
Terk makes a variety of very good antennas.
                                    Cheers
                                     Charlie
JimJ
  • Ut Prosim
« Reply #4 on: 25 May 2007, 07:40 pm »
How do you have the antenna set up?
Do a Google search for "J-pole antennas"...they're vertically polarized and have a bit more gain than a dipole does, might make a difference. For the FM band, you can build one out of 300-ohm twinlead and hang it on a tack.
puft54cs
« Reply #5 on: 25 May 2007, 08:12 pm »
A simple T antenna behind my equipment rack.
BobM
« Reply #6 on: 25 May 2007, 08:18 pm »
If your in the boonies then you may need more, and I would strongly suggest something on the roof, but if you're a suburbanite then you're probably OK with the standard Y wire antenna. You may need to play with the location where it works best, but other indoor powered antenna's really don't do a whole lot more than the wire does.
Enjoy,
Bob
eric the red
« Reply #7 on: 25 May 2007, 09:59 pm »
I have one of these http://www.magnumdynalab.com/fmantenna-sr100.htm gathering dust that you can have for FREE if you want to pay the price of shipping from Oregon (if I ever get home to ship it that is...). PM me if this interests you 8)
Hogg
« Reply #8 on: 26 May 2007, 01:27 am »
I'd suggest reading what the author of this website has to say.  I've not yet ordered his antennae but plan to in the future.
http://www.antennaperformance.com/
Jim
Danberg
« Reply #9 on: 26 May 2007, 03:04 am »
I hate to admit it here but I purchased an amplified antenna from Radio Shack last summer (part #15-1859) after trying a standard Di-pole and various rabbit ear antennas I had laying in attempt to get better reception on my basement workshop tuner.  It made an improvement in amount the stations I was able to pull in and reduction of background noise.
As I recall it was $25 and has a 30 day money back return policy.  I'd give it a try if I were you.
puft54cs
« Reply #10 on: 1 Jun 2007, 08:13 pm »
Thanks everyone, I am sure one, or several, of your suggestions will work for me.
