0 Members and 1 Guest are viewing this topic. Read 11146 times.
There are ways around this. Can't say too much just yet. We'll have something out soon that will be an excellent solution to the 2 channel environment.Bryan
Diffusion seems to be recommended far less than absorbtion for small audio listening rooms.
Quote from: richidoo on 24 May 2007, 01:18 amDiffusion seems to be recommended far less than absorbtion for small audio listening rooms.Yes, good diffusors cost a lot more to make than bad ones. All of the cheap diffusors I've heard sounded noticeably worse than a bare wall. So when someone wants good results but can't spend $2,000 just for diffusors, absorption is a good second choice. Versus cheap diffusors. --Ethan
Quote from: richidoo on 24 May 2007, 01:18 amDiffusion seems to be recommended far less than absorbtion for small audio listening rooms. There are other differences between RealTraps and other manufacturers, but there's no need to belabor that here. I'm good friends with Bryan and Glenn and, first and foremost, we all have the common goal of spreading the word on the importance of room acoustics and treatment.--Ethan
Hold on to your hat there Mr Winer the days of diffusion products that cost a arm and leg are coming to a END. We have something new that works OUTSTANDING (may I add looks cool as hell) coming VERY SOON.
Usually the living/family/bonus room is the biggest and best stereo room in the house, but still under momma's control. It took me 6 months of daily brainwashing to get my wife to finally give in. hahaRich
Definitely go see Heavey Canvus live if you can. I saw them play in Chicago a few years ago and they totally rocked!
Heck, bonding FSK facing to a piece of fiberglass yields some membrane effect.
My goal was not to start a pi$$ing contest
I like the RPG stuff, but it's outrageously expensive. Check out the room at the bottom of this ad, though:http://cls.audiogon.com/cgi-bin/cls.pl?accstwek&1183931697
If your system costs more than about 2k then you need room treatments.
We are definitely in the diffusion camp. We have solved bass problems with proper diffusers!!!!
The most acoustically advanced control room in Nashville uses no bass traps, all diffusion and is getting rave reviews. It belongs to George Massenburg. A critical ear, for sure.
