Power amp output inductor values?
0 Members and 1 Guest are viewing this topic. Read 2413 times.
andy_c
« on: 22 May 2007, 10:02 pm »
Hi,
In another forum, there's been a discussion going on about output inductors in audio power amps.  It was mentioned that the schematics on the Bryston web site show a 2uH inductor value at the output for most (maybe all?) of the power amp schematics listed there.  Then someone mentioned that the Stereophile test data for the 4B at this link http://stereophile.com/solidpoweramps/592bryston/index3.html showed an output impedance of 0.13 Ohms at 20 kHz.  That data would indicate that the output inductor value is closer to 1uH.  So this suggests a couple of possibilities:
1) The Stereophile output impedance data could be in error, or
2) The actual output inductor value of the 4B could be different from what the schematic says.
At first I was inclined to assume that the Stereophile data was in error, but then I saw a note on the schematic that its correctness wasn't guaranteed.  Anybody know if the 2uH value listed on the schematic is the correct one?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Power amp output inductor values?
« Reply #1 on: 22 May 2007, 10:25 pm »
Hi,
Hi Andy,
I will check with engineering.
james
andy_c
« Reply #2 on: 22 May 2007, 11:23 pm »
Thanks James!
Andy
« Reply #3 on: 23 May 2007, 07:18 pm »
Thanks James!
Andy
Hi Andy,
The schematics on the website are in error on the 7B's and the 14B's.
We in fact use 1 uH inductors in the output on 7B and the 14B.
All the other amplifiers (4B) use 2 uH's inductors in the output.
james
andy_c
« Reply #4 on: 23 May 2007, 07:46 pm »
Thanks again James!
Andy
