how to wire subs into stereo system.
0 Members and 1 Guest are viewing this topic. Read 1039 times.
RawB8figure
« on: 20 May 2007, 06:01 pm »
I want to do a stereo set up in my house. I was looking at doing the RA8 from raw acoustics. and power it with the rotel RX-1052 stereo reciever. Ok now I want to hook up a left and right powered subs. How do I wire these in to the system that doesn't have sub outputs.
doug s.
  • makin' music
Re: how to wire subs into stereo system.
« Reply #1 on: 21 May 2007, 03:05 am »
based upon what's shown about this receiver on the rotel website, you could use one of its zone outs for powered subs.  use the sub's built-in x-over to adjust the low pass x-over point.  your mains would have to run full-range, tho, unless you put some sorta passive x-over on the speaker cable...
doug s.
tanchiro58
« Reply #2 on: 21 May 2007, 07:27 am »
If your receiver has an extra pair of outputs (usually receiver has a pair of auxiliary) there is a chance to hook your subwoofer.
Mike Dzurko
« Reply #3 on: 21 May 2007, 01:08 pm »
Most powered subs either have speaker level inputs or come with speaker level adapters. You'd just wire the subs in parallel w/ your mains.
