Bugle + LM4562
0 Members and 1 Guest are viewing this topic. Read 2331 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
Bugle + LM4562
« on: 19 May 2007, 01:46 pm »
Been listening to the LM4562 I got this past week - Best yet.
(http://home.comcast.net/%7Eomaille/bugle/opamp.html). Cleaner, more open, neutral, uncolored, no smudge. Less surface noise, too.
« Last Edit: 20 May 2007, 01:09 pm by PatOMalley »
audiojohn
Re: Bugle + LM4562
« Reply #1 on: 4 Jun 2007, 07:27 pm »
After reading your evaluation, I just had to order some LM4562's! Can't wait to try them. But it leads me to wonder ..... when an I.C. is socketed, is there a chance that over time, a bit of oxidation on the pins will degrade the sound? If so, would removing and then replacing the same I.C. change the sound? What about a good cleaning with one of the proprietary contact cleaners?  It's just a thought.
jpo
hagtech
Re: Bugle + LM4562
« Reply #2 on: 4 Jun 2007, 11:52 pm »
socketed
Same issue with tubes.  Yes, oxidized or other corrosions on pins can screw up sound.  Various ways to clean.  Simplest is to remove and re-insert.  Tubes a lot more robust in this fashion.  Be careful with DIPs.
jh
PatOMalley
Re: Bugle + LM4562
« Reply #3 on: 5 Jun 2007, 06:22 pm »
I haven't had any opamps in long enough to worry about oxidation. But with the LM4562's, I guess I should solder those in.
peranders
Re: Bugle + LM4562
« Reply #4 on: 5 Jun 2007, 06:26 pm »
Sockets are use ONLY if you want to change the IC. If you still want a socket, use one with good quality. Like these:
