0 Members and 1 Guest are viewing this topic. Read 12598 times.
Your budget allow for lots of juicy options. Personnally I'd also consider active studio monitors (small 2-way speakers that have their own amplifiers built-in, one per driver) that deliver huge bass, flat frequency response, and are very dynamic. And can't forget Aspen amps (from OZ) if your handy with a soldering pencil.
millionmonkeys, perhaps these guys are throwing a 'monkey' wrench into the equation for you.... WEEZ
Quote from: JLM on 21 May 2007, 10:12 amYour budget allow for lots of juicy options. Personnally I'd also consider active studio monitors (small 2-way speakers that have their own amplifiers built-in, one per driver) that deliver huge bass, flat frequency response, and are very dynamic. And can't forget Aspen amps (from OZ) if your handy with a soldering pencil.JLMCan I ask you - when you talk about 'active studio monitors' - what brands are worth considering? (ie do the conventional speaker mfrs make them as well or is there a whole new subspecies of company?).TksMM
Quote from: millionmonkeys on 22 May 2007, 07:04 amQuote from: JLM on 21 May 2007, 10:12 amYour budget allow for lots of juicy options. Personnally I'd also consider active studio monitors (small 2-way speakers that have their own amplifiers built-in, one per driver) that deliver huge bass, flat frequency response, and are very dynamic. And can't forget Aspen amps (from OZ) if your handy with a soldering pencil.JLMCan I ask you - when you talk about 'active studio monitors' - what brands are worth considering? (ie do the conventional speaker mfrs make them as well or is there a whole new subspecies of company?).TksMMSome active choices can be see here: http://www.bhphotovideo.com/c/shop/1641/Monitors_Active_Monitors.htmlFor a good explanantion on the advantages of active speakers: http://www.sound.westhost.com/bi-amp.htm
With the active monitors shown on the B&H website (boy I wish we had a company like this in Australia!) how do they stack up against passive speakers? For example, what would be the passive (ie normal speaker) equivalent of the Tascam VL-X5 Speaker(5.25" 90-Watt Biamplified Nearfield Monitor - $299)?
In my mind there are two primary advantages of active speakers: 1) crossover operates on line level signals instead of speaker level signals and 2) the amplifier can be designed for a specific driver instead of being a general purpose amplifier.The negative for many audiophiles is that active speakers takes the opportunity to mix and match components away. I see this as another advantage.We like to think that passive crossovers in speakers behave in a well defined manner according to the speaker's specifications. They don't. The behavior of the filter is dependent upon the load, i.e., the driver. We know that the driver is reactive in nature so it does not present the filter with a fixed load. So the behavior of the filter is a function of frequency. If given enough budget, the designer can attempt to compensate for the driver so that the filter behaves more as desired.For example, Jim Thiel uses first order crossovers in his speakers. You'd expect to see a very simple crossover with few components. Instead, the pictures I've seen are of large boards with literally tens of components.In the line level active world these problems either completely go away or can be managed with greater precision and less cost.Hope this helps a little.
(a) if active speakers have these advantages, why are they (from what I can see) pushed off to the side and looked at as mainly for use in studios (not so much home hifi)?(b) I mentioned Tascam above as an example - which brands of active speakers would you recommend?
