0 Members and 1 Guest are viewing this topic. Read 3268 times.
FWIW ... The only other sub I've owned is the Vandersteen 2wq as well. One reason I chose that sub was because of its 3x8" driver design making it a "fast" sub that could properly integrate with my Magnepans. The fixed crossover required to be inserted between amp/preamp I found to be problematic, but I did like the adjustable "Q".I now have the ACI Force and I have never regretted the change (mine are the older model, but I believe they are identical except for the cosmetics). In addition to being much easier to live with in terms of size, they also offer much more in the way of adjustability to blend with your mains. In fact, I was very surprised by how much the phase adjustment can impact the sound with the continuously variable settings between 0 and 180 degrees (rather than just the one or other found on many other subs). The dual crossover filters are also great as they allow you to adjust the rolloff curve.
How do you like the Force compared to the Vandersteen as far as SQ ,and output?Which was easier to set up?ThanksRyan
