Mac mini OS
0 Members and 1 Guest are viewing this topic. Read 1543 times.
Barry.B
Mac mini OS
« on: 16 May 2007, 11:24 pm »
Hi All,
I'm patiently waiting for Amazon UK to get their act together and send me the 'all black' squeezebox 3 I ordered at the end of March.  When were these released for sale in the UK anyone as quite a few UK dealers seem to be awaiting stock?
Reading an article in the latest Hi Fi News (June issue, letters. page 95 - USB performance - response by Andrew Harrison), it was stated that the Mac mini OS converts all audio files by default to 24/44.1  even if they were originally say 24/48 or higher.
Is this in fact true as I was mulling over the pro's and con's of using an Intel Duo Core based Mac mini to load slim server onto and then hook up a couple of USB 500Gig hard drives as storage for my ripped CD's.
I intend to feed the output of the Mac mini via ethernet to our Draytek Vigor 2910VG router, then wirelessly to the SB3, then via S/PDIF to my Bryston BP25DA pre amp, so I don't want the Mac to down rate the files or is the drop not going to make much difference anyway - I may have got the wrong end of the stick in understanding whats going on here and am happy to be corrected.
Any better suggestions on a storage solution happily accepted, ie what would be the minimum specs needed on a basic PC to replace the Mac mini and get good results with my audio system - the BP25 is feeding a vertically bi amped 3BST/PMC LB1 set up.
Many thanks,
Barry.B
PhilNYC
Re: Mac mini OS
« Reply #1 on: 16 May 2007, 11:31 pm »
You're fine if you're using a SB3.  The conversion to 24/44.1 only happens via the USB output, and I'm pretty sure it's defeatable.  SB3 doesn't use the USB port...
Barry.B
Re: Mac mini OS
« Reply #2 on: 17 May 2007, 06:48 am »
Hi Phil,
Thanks for your reply.
If you are using USB connected hard drives for file storage, then I take it the audio would then be converted to 24/44.1.
How do you defeat this or is it fairly involved.
Barry.B
Grumpy_Git
Re: Mac mini OS
« Reply #3 on: 17 May 2007, 08:16 am »
No.
You will only be using the USB to transfer data, it will stay the same.
If on the other hand you attach a USB soundcard, then you will find that the data is being manipulated.
Until your files reach a soundcard or Squeezebox, they are only considered data and not converted/edited or ruined.
Nick.
Barry.B
Re: Mac mini OS
« Reply #4 on: 17 May 2007, 10:11 pm »
Thanks Nick, seems there's a fairly steep learning curve here. I'd better get climbing!!
Barry.B
