PRICE DROP: Odyssey Cyclops int amp
0 Members and 1 Guest are viewing this topic. Read 1326 times.
nickspicks
« on: 16 May 2007, 10:50 am »
I need to move to different gear to accommodate more than a digital front end.
but...my loss is your gain.  If you are a single source person.., then you might want to check this out.
Odyssey CYCLOPS integrated amp.
its a Khartago w/some sort of volume control via remote.  one input.  one output.  110wpc @ 8ohms.  Currently driving the hefty load of my Martin Logan sequel IIs with relative ease.  By far, the best SS amp i've owned.  I'm not going to throw a bunch of crap terminology at you.  It sounds freakin' great.  cosmetics are almost perfect.  I think there is a scratch somewhere...but I cant see it.
I will include cables...your choice, for cheap money if desired.
one pair is 8' 6awg silver clad single wires (just two leads)
the other is an 8' pair of black bi-wires.  12awg, silver clad...and really nice.  These are an extra $75.
$575 + shiping/fees
some info on the Khartargo / Cyclops amps:
http://www.odysseyaudiosg.com/Khartago.htm
Not much out there, unfortunately.  I dont think this is offered any more as a new product from Odyssey (?).
« Last Edit: 20 May 2007, 01:03 pm by nickspicks »
