I work at an electronics distributor for pro/commercial audio.... one of the few perks is the ability to take equipment home and "field test" it overnight or for the weekend.....
tonight it is a Goldline Real Time Analyzer - Model DSP30 - over $2000 retail.... it really has too many features to list here but the most important is the 30 band analyzer of sound... it includes a calibrated mic and resolution down to .25db....(1/4 of a decibel)
you can check it out at
www.gold-line.comreally pretty amazing...(it better be for $2000)....
now to the point.... i recently aquired a dynaco sca-35 tube amp from ebay to replace a carver tfm-25 in my main system.... sharing this info at work...i got the responses...."tubes color the sound"... "tubes are o.k, but not accurate".... and so on....
o.k...let science help us..... on a test cd of pink noise for each channel and both channels combined.... the dynaco tube amp was down 4db at 16 khz and about 6db at 20 khz.... (now the best part) ... the carver results were almost identical.... the rest of the spectrum was almost flat....
(for the record... the dynaco is 17.5 watts per channel and the carver is 225 watts per channel)
the speakers are Klipsch KLF-30's mated with a Velodyne CT-150 sub set at 40 hz and about half volume....
RESULTS:
both amps produced almost the same result on a piece of expensive test equipment yet they SOUND RADICALLY DIFFERENT!!!!! ... my 5 year old daughter can hear a difference in the sound between the two amplifiers.....
frequency response measures pitch.... but I am not aware of any device available that can measure TONE..... yet we can all hear differences in tone.....
TONE is why we hear differences in most amps and speakers....yet no one talks about it.... as a musician, tone is a top priority...yet it is not discussed when talking about audio components.......???????
i'm probably preaching to the choir here...but i wanted to share my "scientific experiment" with this forum....
