FLYING MOLE DAD-M310 Monoblocks ....... the S.E.T. of Class D amps
0 Members and 1 Guest are viewing this topic. Read 8814 times.
William Crane
    • http://cranehometheater.com/
We are a USA importer of Flying Mole amp, pre-amps and integrated amps.
The DAD-M310 monoblock amplifiers are is Flying Moles most powerful reference audiophile monoblock amplifer. The sound is very sweet, detailed and accurate. If there were a comparison to tube amps it would be to SET amps, but with 10X the power. In fact, they lose absolutely nothing to tube amps, even S.E.T.s, and have all the advantages of Class D with a switch-mode power supply: speed, dynamics, bass control. Truly the best of both technologies!
Plus they have absolutly no RFI which causes interference for some Class D amps to AM, FM and phono sections of ones system. You can set a table radio next to the Flying Moles.
They will light up speakers from Gallo, Von Schweikert, Usher, System Audio, and other fine manufacturers. You will be delighted with the sound.
The DAD-MD310s compete evenly when compared head-to-head against the NuForce Reference 9 V2 Special Edition (SE).
They will challenge any amp, at any price - they are that good!
Levi
Welcome to Audio Circle William.
FLYING MOLE
DAD-M310 Monoblock Power Amplifiers
The S.E.T. of Class D amplifiers
hmen
Specs? Reviews? Prices? :scratch:
William Crane
We sell a new pair of the DAD-M310 monoblocks for $2,495 including USA shipping.
Proprietary Switching Power Supply
* Full Resonance Switching Power Supply ensures energy supply in real time when it is required for dynamic sound.
* Floating Power Supply circuit achieves incomparable speaker drivability.
Original Bi-Phase PWM Amplification for Audiophile Quality Sound
* Latest Bi-Phase PWM (3-Level PWM) Amplification ensures superb sound quality in moderate power range.
* Achieves superb resolution and linearity from minimum to maximum output.
* Dual (Analog & Digital) NFB ensures isolation from AC Power Voltage fluctuation and stable amplification.
DC Amplifier Configuration
The DC amplifier configuration ensures rich, clear musical scale bass and strong powerful presence.
Real Time Current Limiter
Keeps amplifier in Safety Operation Area (SOA) during high level input to maintain durability and continuous operation.
Elegant Cosmetics, Quality Finish, and Superior Parts
* Solid Aluminum Knobs
* Gold Plated Speaker Terminals: 2-Way type
* (Banana Compatible) Gold Plated RCA Pin Jacks : Inputs
* Cosmetics designed by world famous GK Industrial
* Design Inc.
DC 12V Trigger (Input & Output) for Remote Power ON/OFF
Power Switch can be turned ON/OFF by control equipment.
Flexible Connectivity Options
* Balanced Input for long-distance amplification
* Unbalanced Inputs (Fixed and Variable) : CD Players, DVD Players, HDD Recorder/Players and ......
Environmentally Friendly
a. High Efficiency (Amplifier and Power Supply)
* 85% at rated output (DAD-M310: 180W/8Ohms, DAD-M160 : 100W/8Ohms)
* 60% at normal music listening level (DAD-M310: 22.5W/8Ohms, DAD-M160 : 12.5W/8Ohms)
b. Compatible to ROHS directive
Specifications:
Rated Power Output 180W / 8Ohms x 1; 300W / 4Ohms x 1
THD: 0.05% (@90W/8Ohms/1kHz)
Frequency Response: DC-50kHz (+0dB/-3dB) / 8Ohms , DC-20kHz (+0dB/-0.5dB) / 8Ohms
S/N Ratio: 120dB
Input Sensitivity: 1V
Input Impedance: 100kOhms (Fixed, Unbalanced),
47kOhms: (Variable, Balanced / Unbalanced)
Power Consumption: 55W
Mat.Outer Dimensions: WxHxD 8-7/16" x 3-9/16" x 15-15/16"
(214 x 91 x 450mm)
Weight: 8lbs 12oz (4kg)
Flying Mole website: http://www.flyingmole.co.jp/new_en/index.html
Reviews:
http://www.positive-feedback.com/Issue29/ces0715.htm
http://www.audioxsell.com/community/events/3/466/Consumer-Electronics-Show-2007/Flying-MoleCorporation.htm
http://www.shows.soundstagelive.com/shows/avtour2006/rmaf_standout_gma_fm.html
Tweaker
How much for the DAD-M100pro HT and what about availablity? I've been waiting for almost two months for one of your competitors to get some in stock.
I've finally given up on them. Also, do you have a return policy? Restocking fee?
William Crane
We sell a new pair of the DAD-M100pro HT monoblocks for $810 including USA shipping. You will get them in about three business days. At this time, sales on them are final.
mfsoa
ICE? UcD?
William Crane
None of the above, or of anybody else’s technology. Flying Mole is also an OEM company of its modules. They were the gang of engineers that developed Yamaha’s Class D amplifier before starting their own company in November, 2000.
They are fifth in amplifier sales in Japan after well-known big companies like Accuphase, Luxman, Technics and McIntosh.
Levi
Interesting...What is the topology of the amp?
William Crane
Their words are "Bi-Phase PWM (3-Level PWM) Amplification" and "Dual (Analog & Digital) NFB ensures isolation from AC Power Voltage.” Otherwise, they have not released anything else on their technology.
I can say that there is no interference with FM, AM or phono stages as is the case with another Class D amp also using a switched-mode power supply.
William Crane
We have added order pages to our website for the Flying Mole amps:
DAD-M310:
http://cranehometheater.com/FLYING%20MOLE/DAD%20M310%20AMPS%20AD
DAD-M100pro:
http://cranehometheater.com/FLYING%20MOLE/DAD-M100pro%20AMPS%20AD.html
Note that since the DAD-M100pro comes in a choice of unbalanced (RCA inputs) or balanced (XLR inputs), we will ask you of which you want before processing your order.
WEEZ
Curious as to how you would respond to the Stereophile review of the CA-S10 in the June issue.
It's the first bad review I've read in that magazine since I can remember...
WEEZ
William Crane
It is a mixed review, not a bad review. I haven’t had a CA-S10, but it sure sounded great at C.E.S. with Green Mountain loudspeakers.
Please try the SoundStage review for a different opinion:
http://www.soundstage.com/revequip/flyingmole_cas10.htm
