What player and what level of mods
0 Members and 1 Guest are viewing this topic. Read 2733 times.
Adam_Reiter
« on: 7 Aug 2003, 11:11 pm »
Dan, this might be a wierd question.
Of all of the SACD/CD players you mod, what model player and what level of mod equals or just edges out the performance of a stock Sony SCD-1?
Is that even an aswerable question?
Also, is the SCD-777ES with the Absolute Truth mods and the SCD-1 with the Absolute Truth mods identical in sound quality?  If so, or atleast extremely close, I will work on getting a 777es.  I dont think the SCD-1 is worth $700 more on the used martket just for looks.   Any bit helps when you are contemplating a $3400 upgrade... :)
modwright
    • ModWright Instruments
Which Player?
« Reply #1 on: 8 Aug 2003, 05:58 pm »
> mod, equals or just edges out the performance of a
> stock Sony SCD-1/777es?
Not a weird question at all actually.  The Sony 9000ES w/Signature Truth Mods ($1250 mod + $800 player) would easily meet if not beat the stock performance of either SCD-1 or 777ES.  Alternatively, the Sony 999ES with Signature Truth mods ($850 mod + $800-$1000 player) would also get you there, but with a different sonic character.  The 9000ES is a bit richer sounding, while the 999ES is a bit more forward, but also more dynamic and detailed.
Yes, they are equal as far as I am concnerned.
It is up to you:
Sony 9000ES w/Signature Truth mods = ~$2000.
Sony 999ES w/Signature Truth mods  = ~$1900.
Sony SCD-777ES w/Absolute Truth Mods = ~$4500-$4700.
The Sony DVD players with tube mods will get you to about 90-95% of the performance of the A.T. modified 777ES.
Dan W.
Sa-dono
« Reply #2 on: 8 Aug 2003, 06:17 pm »
Let us know what you end up buying Adam. Sounds like you should have a great front end. Would be fun to do a comparison....WHEN we both finish up  :mrgreen:
