dampers?
0 Members and 1 Guest are viewing this topic. Read 898 times.
chgolatin2
dampers?
« on: 14 May 2007, 01:53 am »
I have a set of tube dampers from levytubes.com dont know how good they are but I decided to purchase them and give them a try.  I am also waiting for my new audio rack which I ordered one last weekened a VTI BL 404 I believe.  Now since the rack is MDF material I was thinking about suspending my audio gear on rubber cork type of suspension to reduce vibration on the audio.  So what the best course to use these dampers 2 per tube or 1 per tube, if 1 what will be the appropriate spot for it if 2 then the same question applies.
I've been wanting to separate my audio away from my video equipment for quite sometime I finally had some money to spend on an audio rack  aa the rack is not considered "high end or audiophile type" but she will do for now.  I need a good power strip or dedicated wall ac outlet to my audio gear, once my house demo begin I will ask my electrician to install hospital grade receptacles around the whole house instead of the cheapo ones  :wink:
