Maestro XL Setup Question -Help!!!
0 Members and 1 Guest are viewing this topic. Read 1418 times.
Kyle Kalivoda
  • Guest
« on: 11 May 2007, 02:32 pm »
Has anyone out there setup a Maestro XL for both 2 channel stereo and home theater? I believe the older Maestro could be wired for both but the amp inputs for the Maestro XL seem to be different.
Mike Dzurko
Re: Maestro XL Setup Question -Help!!!
« Reply #1 on: 14 May 2007, 02:42 pm »
Kyle:
The newer, current amp does not have the separate theater input of the older amp. Not that many people used it, and in fact it seemed to confuse more people than it helped. Are you talking about using the Maestro XL with two different systems?
Kyle Kalivoda
  • Guest
« Reply #2 on: 14 May 2007, 02:46 pm »
I have just one system. I wanted to try listening to the sub connected using the line level cables. I heard that configuration is better for two channel listening rather that using the sub out on my Rotel 1098. However I watch movies as well and would need to use the sub out for that purpose.
