0 Members and 1 Guest are viewing this topic. Read 3483 times.
Just take your Mahler 5th with you and turn up at my place to listen.
Unfortunately I come from a theoretical background. As such I have a hard time letting go of the urge to understand the theory first...
You want more than advice, you don't want to use somebody else's simulations or design
I think you are saying you want to understand the fundamentals. You need to do the work yourself and gain the level of understanding that will result. I can understand that, it was where I was many years ago and that is what I did. It just took some effort and time, I don't know any shortcuts.
Adding a ST with only a HP filter (allowing the FR driver to run full range) make the situation worse...The botton line is that adding a super tweeter to any system (not just a FR) isn't really a good ideal if wide, uniform dispersion is desired.
Do a simple test for your self. Just mount two tweeters on a baffle about 6" appart and play some pink noise though them. Sit about 1 or 2 M away and move your head around. You will clearly hear the variations in sound due to destructive interference at different head positions.
