Remote control for 14B ST
0 Members and 1 Guest are viewing this topic. Read 1895 times.
amdan
« on: 10 May 2007, 08:13 am »
Is there an accessory that will enable me to turn the 14B ST on and off remotely? My pre-amp has no remote either so it won't be able to help here. Thanks in advance for any help
ec
Re: Remote control for 14B ST
« Reply #1 on: 10 May 2007, 10:16 pm »
I believe the 14B ST has a 12 V trigger.  There are current sensing devices (ie turn on your preamp) which will then send a 12V trigger to your 14B ST.
Phil A
« Reply #2 on: 10 May 2007, 11:56 pm »
I believe Radio Shack used to sell one.  Not sure if they still do.
Phil A
« Reply #3 on: 11 May 2007, 12:54 am »
From memory, the Radio Shack device I referenced used to look something like:
http://www.cepcoproducts.com/ps1.html
amdan
« Reply #4 on: 12 May 2007, 11:36 am »
Thanks for the posts. I will check out our version of Radio Shack to see if they have anything to help.
amdan
« Reply #5 on: 1 Jul 2007, 02:32 am »
A dealer suggested that I purchase a Bryston Pre-amp to solve this problem. Anybody have an old (and hence cheap) Bryston Pre that they want to get rid off? 240V preferred but 120V will be fine - I will get a transformer.
I couldn't get an appropriate solution from our local electronics stores.
