SonicFlare CHIME Review
0 Members and 1 Guest are viewing this topic. Read 1440 times.
hagtech
« on: 7 May 2007, 06:48 pm »
I'm about to go read it.  But first, let me post the link:
http://www.sonicflare.com/archives/mac-hagerman-koreeda-audio-note-review.php
jh
fmena
General Chime question...( from a newb)
« Reply #1 on: 7 May 2007, 09:00 pm »
I have a tube pre-amp that has way more gain than I need when I feed it with a CD player.  The CD player has a 2V output, but if I were to place the Chime before the tube pre-amp (Foreplay) would I decrease the overall volume of the system, since the Chime's output is maxed at 1.2 V ?  I'm guessing it's possible to build a Chime without the volume control?
Thanks for your time.
Frank M.
hagtech
Re: SonicFlare CHIME Review
« Reply #2 on: 8 May 2007, 02:22 am »
Yes, you can bypass volume with jumpers.  You can even add another switch to select between fast/slow modes of the digital filter.  Probably sound better to go direct and bypass the linestage.  However, that configuration is rarely possible.
jh
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #3 on: 8 May 2007, 05:21 pm »
Jim,
Congrats on the review. As always, you kicked ass with the Chime design  :thumb:.
Best,
Anand.
