0 Members and 1 Guest are viewing this topic. Read 2052 times.
It's patent number 6,338,395. You should also note that speaker Q will change when you use the Kapok material. Typically, this won't pose a big problem, because the difference will be small. However, for the RM40s, you might need to redo the bass damping.Also, the first claim in that patent is suspect in my opinion. They appear to be trying to claim the kapock material itself, independent of any speaker structure. That doesn't appear patentable. It's also unclear as to what is being claimed. For instance, if you're a manufacturer of kapok, do you infringe that claim? Anyway, just an aside.
k7niq,it would be nice if you could measure the low frequency response of your sub before, without stuffing and after modification. For instance by playing a low freq signal and using the radio shack sound meter placed very close to the woofer.Bruno
