Upgrade path
0 Members and 1 Guest are viewing this topic. Read 1329 times.
eosdigic
Upgrade path
« on: 4 May 2007, 02:24 am »
Hi all,
With limited budget, which upgrade path is better?
1. Ref 9 --> Ref 9SE
2. Ref 9 --> Ref 9V2
John Casler
Re: Upgrade path
« Reply #1 on: 4 May 2007, 03:29 am »
Hi all,
I am not speaking from personal experience, but from reports from those who have heard both "path # 2" seems to be preferred.
But that also leaves room for a two stage upgrade:
Stage One = Ref 9 > Ref 9 V2
Stage Two = Ref 9 V2 > Ref 9 V2 SE
TaiPan
Re: Upgrade path
« Reply #2 on: 4 May 2007, 03:51 am »
Hi Eosdigic,
If memory serves me correct, Jason of NuForce stated that the Ref 9 V2 actually exceeded the performance of the Ref 9SE.  Accordingly, it would seem like option #2 is the most cost effective in the long run.
Garry
PS - You Nuforce owners sure are lucky :cuss: b@#%stards :cuss: - great products, great customer service, short turn around time, etc., etc.
rustydoglim
    • www.nuprimeaudio.com
Re: Upgrade path
« Reply #3 on: 6 May 2007, 09:46 am »
Yes, we recommend Ref 9 -> Ref 9 V2.
The cost of going from Ref 9 -> Ref 9 V2 -> Ref 9 V2 SE  is the same as Ref 9 -> Ref 9 V2 SE.
For new customers, unless you need more than 200W of power, we would recommend Ref 8.5 V2.  Similarly, Ref 8.5 V2 and be upgraded gradually to Ref 9 V2 SE.
Or you can skip one generation and wait for V3 (absolutely no idea when that is available as R&D won't start until this summer).
