Nak 3A reciever
0 Members and 1 Guest are viewing this topic. Read 716 times.
bummrush
Nak 3A reciever
« on: 2 May 2007, 09:28 pm »
Just bought one for the heck of it,anyway powers up ,but green lights keeps flashing,and no sound,any ideas.What do i need to know in case i  want to find the fuse,pretty paranoid about opening up,but i might give the fuse a look,,thanks
warnerwh
Re: Nak 3A reciever
« Reply #1 on: 2 May 2007, 10:05 pm »
Do check all the fuses. It's easy to do. Don't stick your hand in there unless you've had it unplugged for an hour or so as the filter caps can hold a substantial charge,  enough to kill :nono:
If any fuses are bad only replace that fuse with the exact same value fuse.  If the fuse blows again then it's time for the receiver doctor.
