Are any of these two cartridge worth to re-tip?
0 Members and 1 Guest are viewing this topic. Read 1130 times.
Jose Garcia
« on: 2 May 2007, 09:04 pm »
I'm referring to an old pair of cartridges I have kept in a drawer and found lately.
Both are from Radio Shack.
Shure RV-15 RS and Shure RXT-4
My actual cartridge is a Grado Red a nd I was considering a NOS Empire 750 LTD.
My table is a JVC QL-Y66F with an Aragon 47K phono stage.
What do you reccomend?
1- Forget the Shures and stay with the Grado
2- Forget the Shures and buy the Empire
3- Re-tip the Shure (which one?) and replace the Grado
4- Keep the Grado and forget the others.
Thanks for any response...
Jose
Nels Ferre
Re: Are any of these two cartridge worth to re-tip?
« Reply #1 on: 3 May 2007, 04:02 pm »
If you decide to buy a replacement stylus, the RV-15 RS model is the keeper of the two, as its a re-badged V15, although I am not sure which series.
The folks at Shure can probably help you with a genuine replacement stylus.   You may want to send them an e mail.  I would go this route before buying the Empire. It's probably the cheaper of the two choices as well.
Don't go for a generic replcement stylus, they are vastly inferior.
