NuForce 9 Help
0 Members and 1 Guest are viewing this topic. Read 1495 times.
eosdigic
NuForce 9 Help
« on: 2 May 2007, 04:46 pm »
Hi Nuforce guys,
Both of my ref. 9.02's LED lights get dark then off during playback. Is it normal?
My dealer said he can replace LED for me, but I think it is circuit issue, not LED itself.
Any suggestion?
rustydoglim
    • www.nuprimeaudio.com
Re: NuForce 9 Help
« Reply #1 on: 3 May 2007, 12:38 am »
For Ref 9.02, The LED light has a diode to regulate the voltage and it draws 5V current from the amp board.
So when the amp is drawing power during playback, less is available for the LED and it gets dimmer. In a few cases where the LED diode is out of spec, it could cut off the power to the LED.
Go to our support website and file a help desk ticket. We can send you two new LEDs for replacement. All you have to do is open up the cover to replace the LEDs with screw driver. No soldering is required. Or you can ask your dealer to contact us for new LEDs.
togil
Re: NuForce 9 Help
« Reply #2 on: 3 May 2007, 06:05 am »
On my 9SEs one of the LEDs is brighter than the other... :)
nuforcelover
Re: NuForce 9 Help
« Reply #3 on: 13 May 2007, 10:34 pm »
also on mine, I have made to change two new led blue. The technician has said that they were different one from other!
