Recommendation for an under $100 MP3 Player
0 Members and 1 Guest are viewing this topic. Read 907 times.
Doublej
« on: 29 Apr 2007, 01:27 pm »
What's decent out there with a display?
Is there anything that will allow me to go straight from CD to MP3 player without having to rip to the computer?
chgolatin2
Re: Recommendation for an under $100 MP3 Player
« Reply #1 on: 29 Apr 2007, 04:22 pm »
I dont believe so, you will still need a computer to rip your cd and convert them into mp3 format.  For the asking price that you want I dont think you could get much especially with a display.  apple.com sells refurbished ipods, also on ebay you get buy ipod clones for under $100 lastly, craiglist is a good place to purchase used gear.  You cant buy much or ask for much for $100
BradJudy
« Reply #2 on: 29 Apr 2007, 08:15 pm »
A 2GB Sandisk player like this is probably your best bet under $100 - http://www.newegg.com/Product/Product.aspx?Item=N82E16855125021
Or Cowan:
http://www.newegg.com/Product/Product.aspx?Item=N82E16855603837
Or Creative:
http://www.newegg.com/Product/Product.aspx?Item=N82E16855102009
As for refurbs, Apple has the current gen iPod Nano 2GB for $110 and the prior gen for $100.
As mentioned, you're pretty much stuck with ripping to the computer unless you want to get something that can record via line-in and transfer that way.  That's going to be pretty annoying (no file naming/tagging, automatic track handling, etc), so I'd only take that route if you don't own a computer at all.  Since you're posting on a web forum, I expect you have some sort of computer already.
robert1325
« Reply #3 on: 29 Apr 2007, 08:34 pm »
The cowons should be good for SQ...
I have a meizu m6 at the moment that sounds quite impressive.   Looks nice to.
Samsung yp-z5 is suposed to be the king of flash players concerning sound quality.    Head-fi is a very good forum for this kind of stuff.
Add some 20 dollar koss ksc75's or 40 dollar Sennheiser px100's and you've got a very nice sounding portable system.    For IEM's have a look at the Crossroads mylarthree at 57 dollars incl. shipping wich should beat most 150 dollars IEM's.... I ordered a pair.
Doublej
« Reply #4 on: 27 May 2007, 01:14 am »
Are there docking stations for non Apple MP3 players or is that a potential major weakness of all non iPods?
