0 Members and 1 Guest are viewing this topic. Read 12178 times.
But if something else is providing the source (say, a CD player), then the operator has to make sure that both recordings are mostly of the same material (and starting and ending at near the same place, within a second or two).
Hope that's what you wanted (or maybe too much?)
When might you use Audio DiffMaker? When you are interested in whether an audio signal is actually being changed by:<much deleted>Devices said to modify electrons or their travel, such as certain treated "clocks"
2) then, the sub-sample shifting is done by trial and error, divide and conquer style: shift a little one way, see how it goes, shift a little the other way, see which is better and start the next loop from there, looking not as far away each time. You need a way to shift by less than a sample -- that's not a problem if the shift (i.e., "uniform delay") is performed in the frequency domain. FFT the recording you want to shift, modify the phase result to apply the delay, then IFFT back to the time domain. You also need a way to tell when the shifted position is better for getting the deepest cancellation over the most relevant frequencies. That is kind of a secret for now, I'm thinking about doing an AES paper on the subject and don't want to give away all the tricks yet! (But it's not all that fascinating unless you are a DSP person, maybe not even then).
