Looking for a "small" cd player..
0 Members and 1 Guest are viewing this topic. Read 4119 times.
es347
  • ..I've got my eye on you...which one you say?
« on: 27 Apr 2007, 02:53 am »
I am looking for a compact cd player, not a portable nor a full size, but rather something in between for bedside table or desktop.  It should have AC input and line level outputs.  A standard size deck is too bulky for my needs but I want something more substantial than a portable.
Thanks in advance for your replies.
ES347
arthurs
Re: Looking for a "small" cd player..
« Reply #1 on: 27 Apr 2007, 02:56 am »
budget?
PhishPhan
« Reply #2 on: 27 Apr 2007, 03:58 am »
How 'bout an Eastern Electric MiniMax.  aa
eric the red
« Reply #4 on: 27 Apr 2007, 09:26 am »
Will a Squeeze Box work?
PhilNYC
« Reply #5 on: 27 Apr 2007, 02:33 pm »
The Cayin CD-50T tubed CDP is 16" x 15.6" x 6"
http://www.vasaudio.com/Product_Name.asp?Category=26:46:27&types=2
(disclaimer, I'm a Cayin dealer)
R_burke
« Reply #6 on: 27 Apr 2007, 09:45 pm »
I use a relatively inexpensive Marantz CD-5001 on my nightstand.  It has an integrated headphone amp so it works really well for the listening that I do in my bedroom
es347
« Reply #7 on: 27 Apr 2007, 10:47 pm »
Thanks for all your replies gentlemen.  The Cayan is beyond my budget; the Squeezebox is interesting but for this listening mode I prefer to stick with cd's; the Marantz being a standard size player isn't quite what I am after.  I did find a smallish player made by Tivoli that looks promising:
http://www.unicahome.com/p30962/tivoli-audio/model-cd-player-by-henry-kloss-for-tivoli-audio.html
Another possibility is a small player by Tascam that is primarily meant for the guitar player as it can slow down riffs for easier learning:
http://www.guitarcenter.com/shop/product/buy_tascam_cdgt1mkii_portable_cd_guitar_trainer?full_sku=103035267
I play guitar and it seems interesting but I'm not sure how it's fidelity compares with a normal player.  Has anyone here auditioned this unit?
The search continues....thanks again guys.
ES347
eastein
« Reply #8 on: 28 Apr 2007, 12:01 am »
You could just load 250+ lossless CD's on an 80 GB iPod
JimJ
  • Ut Prosim
« Reply #9 on: 28 Apr 2007, 12:06 am »
That's dependent on bitrate.
I was going to recommend the Tivoli unit :) Used to have a Model Two, it was built well.
es347
« Reply #10 on: 28 Apr 2007, 03:33 am »
Yes that is possible but I should have told you that I plan to run line level out to my Perraux headphone amp thereby avoiding the normally poor to mediocre headphone amp circuitry.
es347
« Reply #11 on: 28 Apr 2007, 03:36 am »
I understand that the Tivoli's quality is in the same ballpark with the Henry Kloss equipment and perhaps Cambridge Soundworks eqpt.
The Tivoli has R and L RCA line level outputs just like the big boys.  I must admit, it pretty much meets my criteria and goes for $200.
Loftprojection
« Reply #12 on: 28 Apr 2007, 01:36 pm »
Well then look at the Red Wine Audio Imod and you'll have way better sound quality then any of those players you are looking at in a tiny package and wont have to change CDs all the time.
http://www.redwineaudio.com/iMod.html
es347
« Reply #13 on: 28 Apr 2007, 02:11 pm »
Good morning Loft.  I know that the iPod-based systems are really cool and can be relatively high fidelity.  I have an iPod and listen to it religiously whenever I find myself sitting still long enough.  However with a CD collection nearing 1500, I like the freedom of grabbing a disc or two and doing my critical listening via player, my headphone amp and HD600's.  I see, at least in my case, as the two activities being entirely different listening modes.  Thanks for the link.  The modded pod (alliteration unintentional) looks very interesting.  I am and will always be fascinated with the iPod technology.
ES347
