Prices Go Down!
0 Members and 1 Guest are viewing this topic. Read 1633 times.
hagtech
    • http://www.hagtech.com
Prices Go Down!
« on: 26 Apr 2007, 07:35 pm »
In order to do my part to help fight inflation, I'm lowering prices on almost everything.  Most significantly, the RIPPER and FRYKLEANER GOLD will drop $100 down to $399 each.  Assembled.  The PICCOLO will start out at just $299.
Sadly, the CHIME was underpriced, so it went up a little to $1799.  The CORNET MC also went up to $999, but that includes yet more upgrades, better capacitors (I may as well use up what I have leftover from TRUMPET stock), damping, and now your choice of chassis color.  Seems nobody likes the blue.  So I will paint the chassis!  I don't know why I didn't think of this before, as the base coat is already baked on, so there is no chance of peeling or chipping since it also makes a great primer.  Only issue is that the painted version will have no silkscreen.  I suppose I should call this version the "Mk IV" or something.  Here's a list of upgrades from the original CORNET:
  • Constant current sinks
  • 370BX power transformer (240Vac operation)
  • AC voltage select board
  • Capacitors
  • PICCOLO head amp
  • Chassis damping
  • Chassis color
And it is still under a grand.  What other tube phonostage gives you this kind of performance and features?
  • Selectable gain (44, 56, 64, 70dB)
  • Selectable cartridge loading (not DIP switches!)
jh
