PICCOLO & Cornet2 & Denon DL-110/AT-OC9 MLII
0 Members and 1 Guest are viewing this topic. Read 1419 times.
machine
« on: 25 Apr 2007, 02:58 am »
Recently upgraded speakers from 95db efficency to 88 db and find I need more output from my Phono Pre.
Will the PICCOLO work with the DL-110 (rated at 1.6 mV but from what I read it really is closer 2.2 mV)?
How about with a AT-OC9 MLII that has 0.4mV output?
Hoping this is the solution to my problem.
P.S. - the Cornet2 ROCKS!!!
hagtech
Re: PICCOLO & Cornet2 & Denon DL-110/AT-OC9 MLII
« Reply #1 on: 25 Apr 2007, 04:31 am »
The PICCOLO will run with any cart.  Just turn the gain knob.  There is also a way to change the OFF position into a 0dB gain mode by adding a jumper to keep power always on (I do this in the CORNET MC).
Ran out of parts building up proto #3 that uses the surface mount LSK389s, so I'll scavange from #2 and finish it up tomorrow.  Then I have to work on parts lists and pricing.  The half-kit will have these rare and expensive transistors pre-installed.
jh
