0 Members and 1 Guest are viewing this topic. Read 9037 times.
Typically, if I were to mark my subwoofer pre-out as OFF, would that mean that the LFE information gets re-routed to my main front channels.
I ask because I'm pondering whether stereo powered subwoofers (each tapped off the speaker level feed to the main LR channels , rather than the mono LFE channel line level) would work better.
Yo!!! Two subs don't make no difference than one sub. Been there done that!!! Cheers Charlie
a related question i've been wondering about, If one is using 2 subs, one next to each of the main speakers, is there any benefit to running them stereo vs feeding them both the same mono signal? might depend on their crossover frequency i'm guessing?
Quotea related question i've been wondering about, If one is using 2 subs, one next to each of the main speakers, is there any benefit to running them stereo vs feeding them both the same mono signal? might depend on their crossover frequency i'm guessing?You actually will benefit from the dual mono setup.With dual mono subs you maximize their capability since both are assured of recieving the same signal both will reach their limits at the same time and you don't have the possibility of one sub exceeding it's limit while the other still has capacity left.Due to the fact that your ears are only 7" apart you always hear the same thing in both ears at subwoofer frequencies.Channel to channel differences at subwoofer frequencies occur in recordings simply because the recording might use microphones spaced 50' apart or some sort of pan-pot/fader control might be used in the recording process.I use a home theater processor with all channels set to small and one subwoofer under the left speaker and one under the right speaker.This way I can feed my signal to the processor as digital and crossover all channels to the subs in the digital domain before the signal is ever converted to analog.
