0 Members and 1 Guest are viewing this topic. Read 6280 times.
Maybe I should look at another line of tubes to supply with some of our products. I also like the Shuguang EL34 and KT88 tubes. I just don't like having to spend money on more expensive tubes when the consumer is going to install the tube of their choice when they receive the product. Now I just have to find a good supplier for the Shuguang power tubes.
Quality from JJ seems to be pretty consistant. Do they make a 6550/KT-88?WEEZ
IMO if you select a tube that makes your component shine then that's the tube you use regardless of cost.
Do a search on diyaudio for the gold lions. Some feel that people are getting seriously ripped off by these. Don't know if it is true or grinding axes, but the people who comment tend to have a lot of experience.
