0 Members and 1 Guest are viewing this topic. Read 5145 times.
Inspite of dealing with him all these years, speaking on the phone, swapping emails etc. I have never met the man. Perhaps Dubravko could post a picture here?
Just a question for VMPS owners (either speakers and factory owners.. )how can a soundstage be so huuuge??I found the bass very dry so far (please note, only 2 hours playing..). I would expect something more from the 30 M, but I guess is rather normal since the cones still have to get loose and go through the whole break in process..
The huge soundtage is not a bad thing, it's a very good thing since it is with a razor sharp focus. the crossing point is 2 feet in front of me and it works just fine.As for playing with mid-highs adjustments, I planned not to make anything as long as you tell me to do this. If you think even with few hours I can start, I will do. Otherwise I will wait..One thing, I hear more bass around the room than in the sweet spot, a room mode?Cheers,Marco
Definitely, please Dubravko post a picture here!Just a question for VMPS owners (either speakers and factory owners.. )how can a soundstage be so huuuge??
Quote from: Pacio on 25 Apr 2007, 11:51 amThings to try:Bass Traps and acoustical treatments that reduce the interaction of the bass energyMoving the listening position forward or backward an inch at a time to see where the best response is (and beleive it ot not, an ich can make a noticable difference) I had better bass response at 3 feets away from the speakers, but I lost the "you are there" factor, the bass was more present but not as tight as before, I also lost some razor sharp focus, even if the stage remained huge. I do prefer the original positionMoving your speakers closer together or farther apart I moved the speakers closer, no results, and some inches apart closer to the wall, without any difference in bass responsePlacing the woofers to face in, or face out and see what gives the best bass. This is the next trial I will do!Placing the speakers (if possible) along both the short walls, and long walls to see if they interact with the room better.As soon as I can post pictures, you will see that I have a funny shaped living room space, very articulated and uneven, the actual speakers position is the only one I can have there.Moving the speakers closer to the walls, may give you more boundary reinforcement.Reversing the slot on the bottom, so that it fires to the rear instead of forward.If and when possible, open all the windows, and doors in the room. This reduces reflected bass from that area (or changes the timing of the reflection if it opens into another room) and is similar to adding a bass trap there, except it doesn't "trap" it, it just lets it keep traveling.Each of these might offer a differing bass sonic in your room, and finding the right combination of them can maximize your Lower Frequencies.I will post some photos soon, so that you kind guys will have a better picture of my set up.In the meanwhile, thank you very much for your precious help!Cheers,Marco
the finish and the look is top quality (also my Significant Others love them!).
