Equitech Power Conditioner problems
0 Members and 1 Guest are viewing this topic. Read 1517 times.
tanchiro58
« on: 20 Apr 2007, 09:27 pm »
I have owned an Equitech power conditioner for my sources in a stereo system. It starts having problems  couple days ago (did not work). When I switch on there is indicate light with a digital voltage but the outlets do not work. How can I fix it? Anyone have owned Equitech PC? Thanks in advance.
rollo
  • Rollo Audio Consulting -
Re: Equitech Power Conditioner problems
« Reply #1 on: 20 Apr 2007, 09:43 pm »
Is there a fuse? Circuit breaker maybe? Do not mean to insult your intelligence, sometimes we just overlook these things.
rollo
mca
« Reply #2 on: 20 Apr 2007, 09:50 pm »
I would call or email them direct:
http://www.equitech.com/purchase/purchase.html
Russtafarian
  • Typical reaction to the music I play
« Reply #3 on: 22 Apr 2007, 02:40 am »
Check to see if the GFCI breaker on the back panel is tripped.
Russ
