correct wiring
0 Members and 1 Guest are viewing this topic. Read 1149 times.
guest1632
  • Guest
correct wiring
« on: 19 Apr 2007, 03:06 pm »
Hi All,
Simple question:
I am almost done with Greg Ball's 150D amp. I am using some Canare cable which has a braided shield and two wires inside. The wires are blue and white. Ok, so I am setting this up as a phantom ground, with the blue and braid connected at the RCA end. The other end Blue and white are connected to ground and hot respectively. Now here's the q:
The RCA connectors are floating. Another words, they are insolated with both terminals, from chassis. So should I go ahead and just connect the braid to the blue wire,, or find a way of taking that braid to chassis ground.
Ray
