Finishing rosewood??
0 Members and 1 Guest are viewing this topic. Read 821 times.
sts9fan
« on: 19 Apr 2007, 12:24 pm »
I am putting together a few DIY amps and I am going to use this sweet piece of cocobolo I have for the fronts.  My question for you kickass woodworkers is how to finish it?  I would like something that will make the grain pop but maybe only semi gloss.  I would also like to be able to buy the stuff at any good woodworking store.  I have googled but not really liked what I found.
Thanks in advance!
Kris
Daygloworange
  • www.customconcepts.ca
Re: Finishing rosewood??
« Reply #1 on: 19 Apr 2007, 12:48 pm »
Kris,
Rosewood is a very oily wood. Finishes can sometimes have a hard time sticking to it. Even if you wipe the surface with a solvent to remove the oil, the remaining oil in the wood will "wick" to the surface and cause problems later. Shellac is often the only solution to this. You can use the shellac as a sealer only, and then some of the more common finishes, or use shellac entirely as a sealer and finish, (known as a french polish). Shellac is subsceptible to water and alcohol, so you might want to use some type of polyurethane as a top coat.
As far as making it "pop", any finish will. Not one will make it "pop" more than another. Some finishes are more yellow, while others are more clear. Some like the yellow tinge while others prefer a a non yellow clear top coat. That's a personal preference.
Cheers
Christof
« Reply #2 on: 20 Apr 2007, 12:54 am »
How about a coat of linseed oil, let it dry then a spit (thin) coat of dewaxed shellac followed by whatever....
Here is a good link to many different DIYable finish recipes
http://www.thewoodshop.20m.com/finishing.htm
