Mini-tower or Monitor sized speakers
0 Members and 1 Guest are viewing this topic. Read 784 times.
RonB
« on: 19 Apr 2007, 06:07 am »
Hello to all-I have been the owner of a pair of Axiom Audio M80ti speakers for about the past year & while I love the speaker I think I leaped before I looked  :duh: as far as physical speaker size & sound for my 17Ft Long x 14Ft wide room...I'm using a Sherbourne 1250 (125 x 7) amp & I just cant seem to get the speakers set w/ proper or good enough rear & side room to achieve what sounds right to me :scratch: ...there doesn't seem to be any difficulty driving the speaker & achieving SPL's (I do listen to Rock n Roll)  aa the issue is much more that there's no sound stage....& a quite "forward"-"in my face sound" so my question is: if I was to set a budget of $1k for a set of stand mounted mini-towers OR monitor/book shelf speakers what might the readership reccommend?
I'm thinking (& hoping) that by using a smaller (but very high quality specification wise) speaker & adding a sub I'll be able to have a better balance of dynamics & achieve a happier place...while my wonderful wife has been very supportive (budget wise) of my hobby,the subject of room tuning isn't going over well  :nono: so I'm trying to correct w/ equipment change outs?-any ideas?-Thank You!
BubbleChamber
Re: Mini-tower or Monitor sized speakers
« Reply #1 on: 19 Apr 2007, 06:37 am »
Have you try changing your listening position by putting your system in one corner and sitting at the opposite corner?
« Reply #2 on: 19 Apr 2007, 10:29 am »
Some reviewers have noted the Axiom house sound includes a emphasized (hot) midrange which does come across as "forward".
What positionings of speakers/listening have you tried?  What does your room look like?  Does your music provide a soundstage on other systems?  I trust that you know enough to set up the receiver correctly.
A typical set-up, with speakers about 3 feet from front and side walls and sitting near the opposite wall should provide enough room for a soundstage to develop.
If not done correctly, multiple drivers plus crossovers can easily result in a speaker design that cannot image.
OTOH the miking/recording process for "loud" rock music is completely artificial.  What I mean is that each instrument/voice is miked separately to a different channel and mixed down after the performance into two channels.  The producer determines what the mix down sounds like.  In this age of low-fi, earbuds, competition with thousands of media sources, and stimulus overload the marketing pressure is on to have the final recording uniformly loud and very forward.
IMO the biggest challenge in audio is quality of available recordings.  Small ensembles of unamplified music have the best chance of being properly recorded (and they're typically small market genres so the producers are far less pressured to mess with).  At the other end of the market pop, rap, and rock cater to teens who have been exposed to TV, video games, car radios, and other very low-fi sources.
robert1325
« Reply #3 on: 19 Apr 2007, 12:29 pm »
Easy to say for me,  But I love my Hawthorne SI's. They sound quite laid-back but are very fast !  They have a full presentation with nice smooth highs,  my room is 12 by 12 ft .  I owned  B&W 603s3  floorstanders and Some mini monitors with Blaudio drivers.    The B&W's where to much for my room, the mini monitors where plain boring.  ( but very clear )
They are not expensive, have impressive bass  and you could even add some augies. (bass augmentation)
Forgot to say,  they are Open Baffle speakers.
Gooberdude is enjoying them to I think :wink:
join the forum ,  very nice people over there ( AC to ofcourse)
www.hawthorneaudio.com
forum:
http://www.hawthorneaudio.com/forum/
