0 Members and 1 Guest are viewing this topic. Read 11955 times.
HiI have a Michell Gyro SE which I have upgraded with Gert Pedersen's turntable and armbord kits and I also have a VTAF to install as well. The phono stage is the Cornet.The standard power supply is quite simple and cheap with an EI trafo and a couple of caps and not much else. I don't understand why the Origin Live power supply is so expensive but then again many of the manufaturer's seem to charge like wounded bulls for so many products such as the Cartridge Man's Isolator and today I read of an aluminium sheet armboard for the Linn which sells for $5,720!All this made me think that a good DIY power supply should be reasoably easy to build.Bluesky
Hi DougAfter posting a reply I thought this could a great project for many of us vinyl Audio Circle people and I am happy to do some leg work on this with help and input from other members in our community.It could be a sort of vinyl Felicia if you like I am sure it could benefit many of us to improve our power supplies but who baulk at the cost of the products currently on the market!Anyone else interested in this project?Ian
I think doug's idea is a good one, but that supply is overkill! 10amps is way more than needed for the job. Having a bit of overhead is good, but having that much overhead might not be efficient, at least not in space.
