Shengya (Vincent) Dual Mono Preamp-both RCA and XLR out/in puts $500
0 Members and 1 Guest are viewing this topic. Read 1565 times.
Sonny
Hi all, great value dual mono preamp from Shengya (Vincent) audio.
Please see ad here:
http://cls.audiogon.com/cgi-bin/cls.pl?preatran&1180982849
Thanks for looking
Big Red Machine
Does it have remote volume by any chance?
What does it sound like? (other units you would compare it to)
Sonny
Sorry, no remote, a true purist design  :wink:.  I have had the Odyssey Tempest Extreme, Classe preamps, Rogue 66, and heard lots more, both solid state and tubes.  I would have to say that this piece is very open and detailed.  It's definitely tranparent as the Tempest and if using the balanced in out, you'll even get more air and openness.  the soundstaging is exact as well as imaging.  It's not as forward (in your face as some other SS pres, but also, doesn't have the tubie warmth that most tube pres have either.  This was used as a second system, but I am deciding to down size and use my integrated instead of the Shengya and mono blocks.
Thanks for looking!
Sonny
Forgot to mentioned that this is the 110v 60hz version for North America!
Sonny
SOLD!!!
