RM2 hookup to HT Reciever?
0 Members and 1 Guest are viewing this topic. Read 2227 times.
Robby L.
« on: 16 Apr 2007, 06:02 pm »
Building a "budget" system.  Going off the idea of "Get the best mains you can afford and build from there".
My Father-in-law has had VMPS STR's for years and they are AMAZING.
I'm looking at purchasing the RM2's.  My question that some of you dealers/installers may be able to help with is how to hook them up to a Home Theatre reciever?   :scratch:  (remember budget :duh: )  Or is there another method you would suggest on limited coin?
Thanks in advanced for any suggestions.  B has been great answering all my questions about product, but figured this one is a bit more broad?
Early B.
Re: RM2 hookup to HT Reciever?
« Reply #1 on: 16 Apr 2007, 06:32 pm »
I wouldn't suggest hooking them up directly to an HT receiver, especially since they are 4 ohm speakers and most HT receivers aren't designed to handle them. You should consider purchasing a 2-channel amplifier and hooking the speakers to this amp, then the amp would plug into the front L&R preouts on the receiver using a pair of RCA cables.
Robby L.
« Reply #2 on: 16 Apr 2007, 07:34 pm »
Recommend an Amp for the budget consumer for these Loudspeakers?
Brian Cheney
    • http://www.vmpsaudio.com
« Reply #3 on: 16 Apr 2007, 09:01 pm »
The RM2 is available in 4 or 8 Ohms, so if the receiver is rated for 8 Ohms only simply order them that way.
Robby L.
« Reply #4 on: 16 Apr 2007, 09:23 pm »
I love you B!  Didn't know that about the RM2's, thought they were 4ohm only.  Thats what I get for not asking!
You just saved me a TON of internet research on 2 channel 4ohm amps....I can go home now!
Thanks again Brian!
Rob
Early B.
« Reply #5 on: 16 Apr 2007, 10:04 pm »
Even if you order the 8 ohm version of the RM2's, you should still eventually buy a separate amp for improved sound quality. It would be ashamed to purchase such a great speaker and power it with an HT receiver. Luckily, you don't have to buy everything all at once.
hmen
« Reply #6 on: 16 Apr 2007, 10:26 pm »
 I ran my 4 ohm RM2's off an 8 ohm Marantz HT reciever for a couple of months and I had no problems but I agree with Early B. that you should eventually upgrade to a better amp or integrated.
Robby L.
« Reply #7 on: 17 Apr 2007, 12:36 am »
Early and Hmen - totally agree.  Gotta do it in baby steps until I find that money tree.
Already found the "Best bang for the buck".  = VMPS
Then to complete the rest of the HT w/ VMPS and start adding some Amps...maybe a Sub, but I think the RM2's will handle that duty for awhile w/o a sweat.
John Casler
« Reply #8 on: 17 Apr 2007, 12:39 am »
For the budget consumer running RM2's this one would be hard to beat
BEHRINGER A500 REFERENCE POWER AMP 2 x 230W
Should be under $200 street
This ultra-linear power amplifier is the top choice for recording studios and post-production work, yet its amazing price is just the beginning. You get true audiophile-grade performance that delivers 2 x 230 watts into 4 ohms or 500 watts into 8 ohms bridged, with enough headroom to always keep you on the safe side. The A500's advanced convection-type cooling system guarantees stable, noise-free operation, while its servo-controlled design can drive virtually all passive speakers. Specifications: *Output power (1 kHz, 0.1% THD) per channel stereo: 160 watts RMS @ 8 ohms, 230 watts RMS @ 4 ohms. *Output power (1 kHz, 0.1% THD) bridged mono: 500 watts RMS @ 8 ohms. *Weight: 18.5 lbs. *Dimensions: 4" H x 19" W x 10.85" D.
  • For recording studios, post-production, live sound, and hi fi applications
    2 x 230 watts into 4 ohms, 500 watts into 8 ohms in bridged mono operation
    Servo-controlled design can drive virtually any passive speaker
    Advanced convection-cooling for absolutely noise-free and stable operation (no fan)
    Precise level meter and clip indicators for accurate performance monitoring
    Input connections on balanced XLR, 1/4" TRS and RCA connectors
    Speaker outputs on professional "touch-proof" binding posts and 1/4" TS connectors
    Ultra-reliable Toshiba® / Fairchild® high-power transistors
    Independent thermal overload protection with LED indicator for each channel
    High-current toroidal transformer for absolute reliability and lowest noise interference
    Quality components and exceptionally rugged construction ensure long life
    Conceived and designed by Behringer Germany
Should be under $200 street[/list]
gongos
« Reply #9 on: 17 Apr 2007, 01:27 am »
I used my 4 ohm RMs's with a digital Panasonic receiver and never had any problems. It sounded great.
Early B.
« Reply #10 on: 17 Apr 2007, 02:47 am »
I use the Behringer A200 for my subwoofer and it works great for that application. A few days ago I hooked it up to my VMPS Tower II's and it sounded like crap. I think Robby would be better off using the HT receiver instead of the Behringer until he could save enough money for a decent 2-channel amp.
