Standalone DAC ?
0 Members and 1 Guest are viewing this topic. Read 3752 times.
jethro
Standalone DAC ?
« on: 1 Aug 2003, 02:49 pm »
James,
Is there any potential for the DAC in the BP-25 and B60 becoming a standalone box ?
  • The Demo is Everything!
    • http://www.bryston.com
Standalone DAC ?
« Reply #1 on: 5 Aug 2003, 05:12 pm »
Hi Jethro,
Yes - we are working on one now.
james
Ron D
Standalone DAC ?
« Reply #2 on: 6 Aug 2003, 05:48 pm »
James, curious...
1. Will it be the same DAC that is currently in place or are you going to change it in terms of design?
2. Are you considering a multi-channel application?
Tx
Ron
Standalone DAC ?
« Reply #3 on: 6 Aug 2003, 06:35 pm »
Hi Ron,
It will be the same DACs as in the new BP25DA and we are looking at 2-8 channels - geared more to the Pro Studio business.
james
thomaspf
Standalone DAC ?
« Reply #4 on: 8 Aug 2003, 06:28 pm »
James,
If you say multi channel I assume you mean a single chassis hosting DACs for multiple decoded PCM streams?
This comes back to my question about djittering. Since your DAC uses an asynchronous sample rate converter to achieve this, could the same technology be applied to a future generation of the SP1.7 or does this introduce to much lip sync problems?
Cheers
   Thomas
Standalone DAC ?
« Reply #5 on: 8 Aug 2003, 06:31 pm »
Hi Thomas,
I will check with our digital engineer on that one.
james
werd
Re: Standalone DAC ?
« Reply #6 on: 25 Mar 2009, 06:33 am »
Hi Jethro,
james
Did this ever materialize?...hehe. No really is this when u guys started working on the BDA-1
« Reply #7 on: 25 Mar 2009, 10:51 am »
Hi Jethro,
james
Hi werd,
Yes the BDA-1 was what we came up with.
james
werd
« Reply #8 on: 25 Mar 2009, 04:36 pm »
Hi Jethro,
james
Hi werd,
james
Wow ... i guess u wanted to charge more. All the man hours u guys put into it.
MarkBryston
« Reply #9 on: 25 Mar 2009, 10:11 pm »
Hi Jethro,
james
Hi werd,
james
James,
I am new here and this would be my first post...so I apologize as I am sure this has been already addressed, but I have tried to read as many past posts as I could before asking, but just couldnt find the answer to this question....How will we know when a software update will be available for the BDA-1? And are any in the chute for the near future....Thanks
Mark
« Reply #10 on: 25 Mar 2009, 10:32 pm »
Hi Mark,
If we are offering a new software upgrade it would be on our website under "Whats New"
james
MarkBryston
« Reply #11 on: 25 Mar 2009, 11:16 pm »
Hi Mark,
james
Thanks James,
One more thing I know a lot has been discussed here and just about every other forum in the world but as it pertains to the BDA-1 and how it reclocks the incoming data with such remarkably low jitter is it relatively safe to say that: assuming with digital cable coax that if the cable maintains true 75 ohm tip to tip or 110 ohm for AES/EBU that the BDA-1 is relatively insensitive to the cable it is used with?
« Reply #12 on: 25 Mar 2009, 11:54 pm »
Hi Mark,
james
Thanks James,
Correct.
james
