FS: GW Labs DSP digital-to-digital upsample processor
0 Members and 1 Guest are viewing this topic. Read 2031 times.
tdangelo
like new - $399 retail - $275 shipped within Cont. USA - paypal prefered - will split 3% fee.  Works great with the Paradisea DAC!
http://gw-labs.com/products/index.html
From GW Labs:
The DSP is a digital-to-digital upsample processor that converses the PCM (Pulse Code Modulation) digital signal with sampling frequencies ranging from 32-96kHz to 44.1 or 96kHz. It is used between a CD/DVD transport and a DAC (digital to analog converter). It enhances digital signal from a CD/DVD transport and output cleaner digital signal to a DAC. The enhancing process will result in better sound.
Marked sonic improvement is attainable with ANY DAC. Although not all DACs have the capability to accept an upsampled 96kHz frequency, a DAC operates at the standard S/PDIF (Sony/Philips Digital Interface) 44.1kHz sampling frequency will sound better when partnered with the DSP. Of course, greater improvement is possible with 96kHz capable DACs.
The DSP has the following features :
Signal Conditioning (jitter reduction)
Signal Boosting (10 times higher)
Signal Isolation (cleaner signal transfer)
Sampling Frequency Conversion (from 32 to 96 KHz) to 44.1kHz or 96 kHz (user selectable)
Precise Clock Generation. It does NOT use the recovered clock from your transport.
Bit Extension (from 16 to 24 Bits)
Dual Choked-filtered Power Supplies
It has 3 input and 2 output modes :
Inputs - Optical (Toslink); Coaxial (RCA); Balanced (AES/EBU)
Outputs - Coaxial (RCA); Balanced (AES/EBU)
Multiple filters are used to suppress noise generated within and to prevent mains borne noise from entering the circuitry. Despite a mere 6W continuous power consumption, the DSP has an over-engineered power supplies - separate transformer windings feeding 2 low noise rectifiers, followed by choke-filtered capacitor banks. Each bank has 20,000µF filtering capacitance.
« Last Edit: 15 Apr 2007, 09:28 pm by tdangelo »
tdangelo
Re: FS: GW Labs DSP digital-to-digital upsample processor
« Reply #1 on: 21 Apr 2007, 02:12 pm »
bump
tdangelo
« Reply #2 on: 28 Apr 2007, 07:57 pm »
reduced to $250
StereoNut
« Reply #3 on: 30 Apr 2007, 04:20 am »
Can you e-mail or post pix on this unit?
tdangelo
« Reply #4 on: 30 Apr 2007, 12:03 pm »
if you click on the link above and then DSP you will see pics.
Tony
tdangelo
« Reply #5 on: 2 May 2007, 02:51 pm »
sale pending.
nightvoyager
  • Audio Freak
SOLD!!!
« Reply #6 on: 23 May 2007, 02:38 am »
SOLD!
I bought it...... aa
