What's the input impedance of the Mono Extremes
0 Members and 1 Guest are viewing this topic. Read 1219 times.
Musicalmaniac
« on: 15 Apr 2007, 05:03 pm »
Hey Fellas,Klaus or Alex.  Anyone know the input impedance of the Mono Extremes? They're the newer ones with the red boards,less than a year old. I'm having some work done on my pre and need this spec for that. Thanks man.
bpape
    • Sensible Sound Solutions
Re: What's the input impedance of the Mono Extremes
« Reply #1 on: 15 Apr 2007, 05:30 pm »
I've heard 11k and 18k.  Probably best to just call Klaus and ask if you need the info quickly.
Bryan
Lkdog
« Reply #2 on: 16 Apr 2007, 01:33 am »
I have a pre with an output impedance of over 2K.
No problems at all.
The Candela has an output impedance of 2K.
No issues.
