Refinishing speakers with veneer....
0 Members and 1 Guest are viewing this topic. Read 5168 times.
Jay S
« on: 31 Jul 2003, 01:22 am »
I have a pair of Acoustic Reality Avinci 1 speakers.  They sound great but I am not fond of the very plain black ash finish.  Is it feasible/practical to refinish them?  I have come across sites selling beautiful wood veneer (e.g. http://www.formwood.thoseinternetguys.com/sampleselect/index.htm).  Um, duh, so what next?  Do you cut and glue the veneer to the cabinet and voila, you're done?  Or does the veneer look really rough and require lots of finishing?  I would love to get the wood to look like what you see on ProAc Response speakers, a nice understated no-gloss finish.
Any suggestions appreciated as I have no clue about wood working/finishing.  Thanks!
shokunin
« Reply #1 on: 31 Jul 2003, 05:58 am »
Veneering isn't too tough, although finishing speakers with a near-flawless finish is easier said than done.  The problem you're going to face is that your speakers are already has a finish on it.  Meaning, gluing another veneer on top of it will be tougher and potentially more troublesome (air pockets) than if you were working with unfinished wood.
You can get veneer, either standard or paper backed.  The paper backed stuff is thicker and somewhat easier to work with if you haven't veneered before.  The paper backed stuff is also more expensive, but I would recommend the paper backed stuff in your case.
You'll have to try and remove as much of the original finish as possible by sanding.  Then, you can use contact cement on both the cabinet and the veneer.  THen apply the veneer and trim the excess with a veneer saw, sharp razor, or with flush trimming bit and a router.  Since veneer is VERY thin, you won't need to do much final sanding.   You'll also have to trim out the speaker cutouts as well.   then comes the finish, you're choice here of what you want, gloss, semi-gloss, film vs. oil, etc.  This will be mostly personal preference and whether or not you want to spray vs. brush vs. wipe on.   There's oil/varnish, lacquer, shellac, polyurethane, or some other mixture.
If you're uncomfortable doing any of this, take it to a professional cabinet shop where they can veneer it for you OR you can make another set of cabinets with MDF and put your own veneer on.  This way should something go wrong, you're not left with irrepairable damage on your original speakers.
nathanm
« Reply #2 on: 31 Jul 2003, 10:01 pm »
In other words, it's a major project - perhaps you could reconsider and find that the black ain't so bad after all! :lol:  Better now than when you're up to your elbows in contact cement and having second thoughts...
If you are not wood-working savvy I wouldn't start with a re-veneer job on an expensive set of speaker cabinets.  Maybe find something else to experiment on before jumping into the big stuff.  It's a process that is all to easy to screw up, so better to do it on a scrap piece first.
Not trying to discourage, just saying...:)
shokunin
« Reply #3 on: 2 Aug 2003, 12:31 am »
Nathan's right, veneering and finishing seems easy to do, but you'll have to experiment on something easy first.  I would NOT try your first veneer job on an nice set of speaker cabinets.  Make / buy a wooden box and try to veneer/finish it.
Real veneering takes a good veneer press or vacuum press to veneer 3D objects.  Contact cement is only recommended if you don't have access to veneering equipment, otherwise I'd use a more rigid glue like UREA resin, epoxy, or polyurethane catalyst glues.  I believe there are even some peel/stick type veneers, but I question their longevity.
JohnR
« Reply #4 on: 2 Aug 2003, 12:40 am »
If you're going to the trouble of veneering them, you may as well just build new (sturdier) boxes.
