Car CDP is skipping
0 Members and 1 Guest are viewing this topic. Read 941 times.
R_burke
Car CDP is skipping
« on: 12 Apr 2007, 07:49 pm »
Are the dry brush cleaners any good, and are there some that are better than others
gooberdude
Re: Car CDP is skipping
« Reply #1 on: 12 Apr 2007, 07:59 pm »
I keep reading that they shouldn't be used.   anything that whips against the tiny glass bead on the laser is bad and can knock it out of adjustment...supposedly.
Mine is starting too also, a 4 yr old Alpine.  Might be time for a new one, or maybe a careful cleaning...not sure how to do that though!
years back in a Shaper Image catalog they have a cd that had fan blades in it, and when it spun it started a cyclone inside, and this removed crud from the laser.    I've looked but can't find that.
Not sure if sending dust throughout a cdp is a good thing anyways!
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 13 Apr 2007, 06:07 pm »
Guys,
            Camera lens cleaner and lens paper work very well. Just be gentle with laser assembly. This is for CDP at home with the car if you can remove CDP give it a go if not, do not have a clue.
rollo
