0 Members and 1 Guest are viewing this topic. Read 11455 times.
falls off the baffle with 3 dB from 2 pi steradians to 4 pi steradians
While the floor effect in terms of boundary reinforcement is quantified at +6db, I've never seen it quantified in terms of the effective baffle.
Fequal is defined where the front and rear waves are 120 (or 240) degrees out of phase. The vetcors of the front, rear and summed result form an equilateral triangle. Since they start at 180, an additional rotation of 60 degrees is requires which comes when the 6 times the effective separation of the frequency is F = C/(6d), where C is the speed of sound and d is the separation. Often written as F = 0.17C/d (Hint, 1/6 = 0.16666666... or approximately 0.17).
John,I really like your last post here. But isn't it time that we introduce The Earth Crisis Climatic Conditions also into our Hi-FI World ! /Erling
A tank of gasoline lasts me about 2 months, so I'm doing my part.
Quote from: JohninCR on 13 Apr 2007, 11:58 pm A tank of gasoline lasts me about 2 months, so I'm doing my part. Except you they are cutting a lot of wood for your speakers. So, pls put them on a container and ship them to Sweden (incl. the speaker drivers, thank you). I honestly promise I will recycle them here
Actually D is the Differential in the travel distances of the front and rear waves to the listening position. eg for a circular baffle "D" is the radius. There are a number of complicating factors as well. While in free space a driver centered on a 48"H x 24"W flat baffle is going to have better bass extension than one 24"x24", in normal usage with the bottom edge on the floor the 24"x24" will outperform the larger baffle, because the effect of the floor is greater in terms of baffle boundary and the driver is closer to the floor too.
QuoteActually D is the Differential in the travel distances of the front and rear waves to the listening position. eg for a circular baffle "D" is the radius. There are a number of complicating factors as well. While in free space a driver centered on a 48"H x 24"W flat baffle is going to have better bass extension than one 24"x24", in normal usage with the bottom edge on the floor the 24"x24" will outperform the larger baffle, because the effect of the floor is greater in terms of baffle boundary and the driver is closer to the floor too.I agree with your statements. However, if you take your 24" square baffle with the driver centered, and add a 24" square baffle above it, D is going to increase by the Square root of 2. D' = D(Squ(2)) Where D" is the 24 * 48 D.This should allow for about a half octive deeper base, without any real penelties.Doug
