0 Members and 1 Guest are viewing this topic. Read 6421 times.
I'd run it with the closet doors closed and plan on things based on the shorter dimension. You'll still want some basic absorbtion in the closet just to keep resonances down.
IMO what you currently have is VERY short on bass control - and general decay time control. You have tons of diffusion and little to no absorbtion. Consider permanent/portable treatments that would let you treat all 4 vertical corners pretty much floor to ceiling. While the 16" tubes are nice, they're not going to reach very deep into the bass. To do that with tubes, you need the BIG ones. A more solid triangular type absorber that will tuck right into the corner will be more effective down deeper.
