iMod freeze after updating rockbox. HELP please!
0 Members and 1 Guest are viewing this topic. Read 2513 times.
Paul_Bui
  • Rode NTK and S-1 microphones
« on: 12 Apr 2007, 03:21 am »
Vinnie installed Rockbox before he sent the iMod/iPod to me.  It's been running fine for a few days, except that not all functions especially Playlist seemed to manifest or function as described in the online manual.  So today I attempted to update it to the latest version of rockbox.
I downloaded the rockbox.zip file (for iPod video - perhaps the wrong file - should have been for iPod color) and unzipped it onto root directory of the 60gb iPod.  After it's done (and until now), I reset but nothing  has happened except that the Apple picture keeps showing on the display.  Vinnie happens to be away from 4/11 to 4/16 to the FSI Expo in Montreal.
I am so desperate.  Please HELP!
JDUBS
Re: iMod freeze after updating rockbox. HELP please!
« Reply #1 on: 12 Apr 2007, 03:56 am »
Yep, you need to use a version of Rockbox designed for the Color model.  I would HIGHLY recommend the latest from:
http://mikeage.net/content/rockbox-custom-builds/
The Rockbox website (http://www.rockbox.org/) describes how to go about ubdating the software.
-Jim
Paul_Bui
« Reply #2 on: 12 Apr 2007, 04:52 am »
Thanks Jim for the pointers.  I was able to reset to disk mode and install the proper build.
Happy listening!
Whew!
gooberdude
« Reply #3 on: 12 Apr 2007, 02:44 pm »
Don't ipod problems just make you crazy????    :banghead:
Good to hear the issue was resolved Paul.
matt
Paul_Bui
« Reply #4 on: 12 Apr 2007, 02:50 pm »
Yup, another learning curve for me.
Thanks for the PM, Matt.  This Imod is a gem indeed.  I may like it better than the SB2/Altmann/TVC combo in the 2-channel system.
jrebman
« Reply #5 on: 12 Apr 2007, 06:12 pm »
Ok, then you can just send those to me and I'll find a  good use for them :-)
-- Jim
