Poll
Do you ever click on URL links within an Adobe Acrobat PDF file which then open in a web browser?
Often
3 (50%)
Sometimes
2 (33.3%)
Rarely
0 (0%)
Never
1 (16.7%)
Total Members Voted: 6
Voting closed: 24 Apr 2007, 10:43 pm
Do You Ever Click URL Links Inside a PDF?
0 Members and 1 Guest are viewing this topic. Read 1548 times.
nathanm
« on: 10 Apr 2007, 10:43 pm »
Just wondering if this is something anyone ever does and if so, is it actually useful in some way?
chadh
Re: Do You Ever Click URL Links Inside a PDF?
« Reply #1 on: 10 Apr 2007, 11:13 pm »
Yep.
Often I'll search for a research paper somewhere, or some other type of manuscript, or perhaps a data source or some set of charts or statistics.  These sorts of things are often prepared separately from the a web document, and are made available as a pdf document.  Citations and references, or simply links to related pages are just as useful there as they are on a normal webpage.   Especially as pdf documents can by opened in the same way as a webpage, links in these documents seems as valuable there as they are on a normal webpage.  Given that the pdf document and the webpage, then, are serving similar purposes, the relevant question seems to be why you would prefer to use a pdf document rather than a webpage.  And the answer to this is presumably in the ease of preparing the document, and the range of uses for which it's designed.  That's why manuscripts and data sources seem to be pdf documents (for portability), while other content seems to be available via normal webpage (for ease of creating nice effects).
Interestingly, the difference between the two will presumably shrink over time.  Even now, if I create a document in Word I can convert it to pdf or to html with a click of a button.  Obviously, using Word as an html editor in this way is a miserable option...but I imagine html functionality will improve over time in these applications.
When I create documents for my students, I also find it useful to include web links.  As the pdf file is a reasonably efficient way to make these documents available, I will often have URL links in my pdf documents.
Chad
andy_c
« Reply #2 on: 11 Apr 2007, 01:34 am »
The Mouser electronics catalog is in PDF form and has web links.  It's sometimes quicker to find items in the PDF rather than on their web site.  Then, when you find the part you want, you can click on the Mouser part number and it will launch the browser and take you to the Mouser web page that lists the part.  You just fill in the quantity you want to buy and click the "buy" button.
That's the only reason I've had to do this, but recently I've been doing it quite often due to a project I'm working on.
