Odyssey Extreme Mono Amps, Tempest, and Dedicated AC Lines
0 Members and 1 Guest are viewing this topic. Read 1280 times.
djbnh
Had dedicated AC lines installed and let them burn in for a while. One result is that my already high opinion of Odyssey's products has been elevated even more. In my system with my gear, quality power paired with Odyssey products = sonic bliss. The downside is that your hearing may suffer; my daughter and I found ourselves wanting more and more volume when rocking out this past weekend. Klaus, your gear kicks serious a**.  :thumb:
Christof
Re: Odyssey Extreme Mono Amps, Tempest, and Dedicated AC Lines
« Reply #1 on: 9 Apr 2007, 09:40 pm »
I don't have mono Extremes but I am running two stereo khartago amps in a vertical biamp config to my SP Tech Timepiece 2.1's. Each amp and my preamp has their own dedicated 20A circuit w/ isolated ground.....I feel your pain :thumb:  Klaus's amps deserve good clean power.
TomS
« Reply #2 on: 9 Apr 2007, 10:10 pm »
I'm using two dedicated 20a circuits with cryo'd outlets from Sound Applications for my Mono Extremes.  I have a Running Springs Audio Haley for the front end components.  I'm still trying to decide if I like the mono's better direct to the wall or through the Haley at this point.  They sound great so far either way but they're just getting burned in right now.  The biggest improvement I made was going to the Black Sand Silver Reference MK V power cords.  They are far and away better than any cords I've heard in my system.
Tom
