Is the AudioPath Silver i-Pod Cable good with PC soundcards?
0 Members and 1 Guest are viewing this topic. Read 1807 times.
isamu
Hi. I'd like to know if the AudioPath Silver i-Pod Cable can be used with PC sound cards with the same line out connector. Let's say I have a KILLER sound card like the 1616M by E-MU and have it hooked up in my car to the *The Soundgate ALMBAUX* for my Mercedes via the AudioPatch Cable...will it improve the sound over a simple $10 Radio Shack cable?
Vinnie R.
    • http://www.vinnierossi.com
Hi Isamu,
If your soundcard has a 1/8" stereo jack, you can use the Audiopath Silver iPod cable.
YES!
Best regards,
Vinnie
