15amp to 20amp
0 Members and 1 Guest are viewing this topic. Read 2177 times.
HPower
15amp to 20amp
« on: 7 Apr 2007, 01:03 pm »
Hi Guys,
I am in the process of running 4 new dedicated 10/2 lines to my system that  will be capped off with
a couple of Shunyata SR-Z1 outlets.
This will be 1 line  for my Musical Fidelity CDP, 1 for my Modwright SWL 9.0 pre, 1 for my Bryston 14Bst, and
1 extra for later use.
I have a call out to Cam at Bryston to find out cost and what is involved to upgrade my 15amp 14B to
a 20amp version.
I thought it might be a good idea to look into this while I am doing the new electrical service to the system.
 :scratch:
Has anybody done this conversion to their Bryston or had any comparisons between a 15amp vs a 20amp model?
If Cam can do the conversion at a reasonable cost I figure that it can only improve an already great amplifier.
Plus it will provide a chance to give the unit a once over.  :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
Re: 15amp to 20amp
« Reply #1 on: 7 Apr 2007, 01:46 pm »
The advantage of the 20 amp version (vs 15 amp) of the 14B is the ability to deliver more current at very low impedances.
james
HPower
Re: 15amp to 20amp
« Reply #2 on: 7 Apr 2007, 02:20 pm »
Hi James,
I am running PMC OB1's, not exactly a pair of Apogee Scintilla's, would that mean
there would be a slight advantage or more like none?
I don't have any plans to change speakers any time soon, but I guess if I ever
did, the 20amp conversion could offer a wider range of options?
Re: 15amp to 20amp
« Reply #3 on: 7 Apr 2007, 02:57 pm »
Hi Hpower,
On a 4 ohm or less speaker I would say the 20 amp version is worthwhile. Remember you have to have a 20 amp plug hydro service.
miille77
Re: 15amp to 20amp
« Reply #4 on: 22 Dec 2007, 10:08 am »
Hello HPower, i to have a 14Bst 15 amp version. Did you go through with the upgrade to the 20 amp version? How much did it cost, if you don't mind me asking. I have a pair of psb gold i that are very power hungry. Thanks
Gary Listen
    • Listen Law Office
Re: 15amp to 20amp
« Reply #5 on: 22 Dec 2007, 10:56 pm »
James,
What does "20 amp plug hydro service" mean?
Thanks.
Re: 15amp to 20amp
« Reply #6 on: 23 Dec 2007, 02:31 am »
James,
Thanks.
Hi Gary,
A 20 amp wall socket plug and minimum 12 gauge wiring in the wall.
james
